01-18-2016 11:19 PM - edited 01-18-2016 11:19 PM
I have Baymer PXU-120M.Q camera, but it is very slow to establish a session. MAX finds the camera and puts it on the list but every time it is selected in MAX or every time a vi opens a session to it, the delay is about 20-30 seconds. Once the session is opened the camera can be triggered and read just fine. Is there some configuration problem that could cause this delay? LabVIEW 2014
01-25-2016 12:48 AM
there is a vi icon to find camera information try to use to find information about the camera and try to use them in imaqdx property node to fix this problem
01-26-2016 07:03 AM
Sorry, I didn't get you. It will be good if you can post the small example code of what you are trying to tell.
I am using the Grab.vi example code of LabVIEW the first vi IMAQdx open camera.vi is taking 30seconds to execute and the rest is normal.
02-18-2016 05:02 AM
Can someone suggest me sollution to the problem mentioned?
I would appreciate any suggestions.....
Regards
A_SK
02-18-2016 06:05 AM
02-18-2016 06:34 AM
Thaks for the immediate reply....
In even NI MAX also camera takes 30seconds to open the camera.
02-18-2016 06:43 AM
02-18-2016 07:26 AM
I have updated the IMAQdx and NI MAX to latest version, but still the problem exists. Is there any way i can control the interface file to connect to camera in NI MAX.
02-18-2016 07:47 AM
02-22-2016 04:09 AM
It will be good if anyone from NI Vision team answer to this question.
