09-09-2014 01:29 AM
BCG lookup and Line profile are inbuilt NI examples and i like to them have in my application, but they have individual while loops. How can I have them both in a single loop and while running switch to one by one when needed? Is Event structure helpful?
09-09-2014 01:56 AM - edited 09-09-2014 01:56 AM
I do not understand what do you mean by "they have individual while loops"? You mean, you use them in two seperate while loops?
Can you provide an example?
I do not know what exactly you are trying to achieve, but you can use case structure (state machine).
K
09-09-2014 09:09 PM
My application includes image processing which needs line profile & BCG. I wnt to change the values of BCG paramaters and also want to use lineprofile while running the VI (as in the examples). I'm posting the example VIs running at different wihile loops. I like to have both to come under a single loop.
09-10-2014 12:58 AM - edited 09-10-2014 12:58 AM
you could use an event case, reacting to both the BCG values change and the ROI draw. You can change BCG and the line profile will update and vice versa.
Please see the attachment (saved for LV 2013).
K
09-10-2014 08:29 PM
Thank you clemen for your support!!!
Can you please explain how can I extract phase information of a complex image plotting it in 3D and unwrap it. I couldn't find any module for phase unwrapping.
09-11-2014 12:31 AM - edited 09-11-2014 12:32 AM
I suggest opening a new thread for your question.
K
