09-02-2014 04:34 AM
Hey Guys
When I tried to Execute BCG Lookup on a complex image , the VI shows error. Does anyone know how to get rid of it.
Thanks in advance.
09-02-2014 04:50 AM - edited 09-02-2014 04:55 AM
complex single is 8 bytes of data, whereas the BCG lookup only accepts 1 byte datatypes. I would guess that this is the problem, but the error of datatype mismatch is usually reported instead of the error you've posted in the screenshot.
Also, if I see correctly, the image reference passed to the BCG lookup "src" has no image (I cannot see behind the error).
P.S. Check the function's help in order to see what datatypes can be passed to it.
K
