09-24-2015 07:54 PM
Hi all,
I am setting up a line scan camera with PCIE1433 and CameraLink interface. The line scan camera is a 4096 line, and after settling up I was able to show the continuous single line inside the NI MAX. I can set the camera file parameter to change picture height to 1000, 100, 1 according to what i want, and here are some interesting questions as follow: If I set the picture height to 100, does that means right now I am acquiring 100 lines and displaying it as a 4096*100 frame? Another question is: Let's say the line scan camera has line rate at 1k and I set as 100 lines for heights on the MAX, does that mean the frame rate become 10?
Thank you for the replay,
Louis
09-24-2015 09:11 PM
You are correct on both. 100 lines creates a 4096*100 frame, and would make the frame rate 10 fps if the line rate is 1000. (1000/100 = 10).
Bruce
09-24-2015 10:03 PM
09-25-2015 08:59 AM
In this case, I would acquire frames no larger than 1000 lines to avoid timeout issues. You can always combine multiple images into a single image after the acquisition. This also gives you the option to cancel the acquisition before the entire thing completes. Eight seconds is a very long time to wait for an acquisition.
Bruce
