Machine Vision
Access vedio from IE
I need to access vedio from IE and take snapshots of that vedios is that possible using LabVIEW, what are the functions we will use for that.
@nk
(4,742 Views)
Do you want take a screen print using labVIEW?
(4,639 Views)
well i did something like that, jus there are a problem, the snapshot  return from the Ip Cam  is in HTML code, so how can i convert to image jpeg? VI camara ip.jpg
(4,376 Views)
