05-18-2016 11:02 PM
In imaqRake, we can use subpixelDivisions to set maximum number of subpixel divisions , but in imaqRake2, I can't find any config to set subpixel divisions,
So, Can any one tell me how to set subpixel divisions in imaqRake2?
05-19-2016 11:28 AM
unfortunately some of vision toolkit vi have some unused change rake vi do not support subpixel
after version 2 for rake 3 you can find sub pixel data in line result and inside the edge info I think in rake 2 still you can find it in edge info
see this array and inside clusters
05-26-2016 05:42 AM
hi- If I may explain this more.Thanks
05-26-2016 05:58 AM
I want value RGB each of the pixels of an image in my red array .
thank you .
05-26-2016 06:56 AM
what is your means want value RGB each of the pixels of an image in my red array .
also did you see the image I attech with name of rake
05-26-2016 10:14 AM
Yes - there is not Diagram . if possible the diagram attach .
thanks .
05-26-2016 10:55 AM
try this my Friend
05-26-2016 05:34 PM
Thanks very much from you. excuse me ....Version of this program is it ??
05-26-2016 06:07 PM
for use this icon Must installing what vision of labview ??
I have Only vision Assistant..
05-27-2016 04:19 AM
I work with 2014 but I could send you a gimage of code you can use it in any version that have rake vi
