Machine Vision
About Auto Find Straight Edge Setup
I use NI Vision Assistant's Find Straight Edge Setup function, this is a "Auto Setup" can auto calculate the Edge and then display find edge's parameter, such as
     Minimum Edge Strength
     Kernel Size
     Projection Width
     Gap
See the attachment picture
now I use same parameter to Find Straight Edge, some picture's grayscale is different, so I often can't Find Straight Edge by same parameter,and then I want to do some process like NI Vision Assistant's "Auto setup"  in ordhe edge, It's best to use labview code,
someone can help me!
very thanks!!!
(2,729 Views)
NI vision assistant could generate labview code according to you set up, if I remembered right.
would you please try this way?
(2,691 Views)
You can try the Vision Assistant Express VI inside your LabVIEW Code and use the same settings, with Auto Setup Checked.
uday
(2,687 Views)
