01-09-2017 07:01 AM
hi,
i am using labview 2015 and vision assistant 2015.i try get all setting what are all show in vision assiatant but i can't able to get suggest value button functionallty.
when i click in Vision assiatant this button it automatically adjust the settings value. but when i convert into vi.this button option not showing.how can i use this button in vi code.
01-09-2017 12:30 PM
I have looked at this function and could not find it as you already mentioned. I believe there is a loop running on Vision Assistant, which tries values and suggests fastest parameters. So, if someone share the algorithm behind that, we can create such a function.
01-09-2017 10:30 PM
hi,
me also think same.how to run the loop and which are the parameter can i increment ,decrement.
01-12-2017 05:11 PM
Here is some code that can be used to suggest datamatrix parameters, similar to what Vision Assistant is doing behind the suggest values button. I am attaching a zip file that contains 2 VIs. The main VI you want to use is "Data Matrix Suggest Values.vi".
Hope this helps. Let me know if that works for you.
Christophe
10-24-2017 06:38 AM
Hi Christophe,
I came across your VI posted for Data matrix suggest values. But I am getting an error constantly when I pass my image and ROI.
Error -1074395635 occurred at IMAQ Read Data Matrix Barcode 2m
IMAQ Vision: The passed shape descriptor is invalid.
the ROI being passed is a rectangle. I have 34 barcodes in a single image and trying to decode them all.
I need a solution for this very badly. Appreciate your help!!
10-26-2017 12:35 AM
Hi..anyone who can suggest a solution for this.
04-05-2020 01:15 PM
Hi, I just got this error like you when I tried to inspect a DataMatrix Code: the passed shape descriptor is invalid.
On the Barcode Size Option, I reduced the minimum size of the bacode to 0 and the maximum to 1000.
Good luck
