NI Home
Cart Cart | Help
You are here:
Reply
Member
IsaacT
12 or 8 bit depth problem
I am using the linked Vi to grab a 16 bit image from a camera link camera.
However, the output image is always 8-bit regardless of my settings and the MAX settings.
Max sees the image as 16 bits without problems.
I actually succeeded in recording 16-bit images with this setup before, using the previous version of the NI-IMAQ drivers, but other camera properties did not work.
Any Ideas on what I could be doing wrong?
Active Participant
rpursley8
Re: 12 or 8 bit depth problem
I don't think your version of IMAQ supports Grayscale(U16).  Change the image type to Grayscale(I16) and see if it works.  Then you will know for sure.
Randall Pursley
Member
IsaacT
I have tried all the settings for the IMAQ create vi, none of them work...
Active Participant
DavidS.
Hi IsaacT,
To understand what could be wrong, could you please give us the NI-IMAQ driver version and the model of your camera and your framegrabber?
Sincerely
David S.| Certified LabVIEW Associate Developer
National Instruments France
Journées Techniques LabVIEW 2012 : du 27 septembre au 22 novembre
2 sessions en parallèle : Débuter a...
Member
IsaacT
Hi
I'm using a 1433 frame grabber, a Baumer HXC40 camera, and version 4.6.4 IMAQ drivers.
Thanks a lot for your help.
Active Participant
DavidS.
When you say that "I actually succeeded in recording 16-bit images with this setup before". that was with this camera?
Member
IsaacT
Yes, same camera, same frame grabber, simply the previous version of IMAQ drivers. I am almost certain it was the same vi that succeeded in recording 16bit images.
Active Participant
DavidS.
Could you use a property node "Image parameters >> Image Type" on the IMAQ Session out to see what is the image type use by the frame grabber?
Member
IsaacT
The image is definitely reported as "Grascale(U8)". It is very strange, since MAX sees it as a 16bit image ( see attachment) and A 8-bit version looks very different(see attatchment 2).
(the change in size is just to keep acceptable file sizes)
Active Participant
DavidS.
Ok so you could probably use the VI IMAQ Set Camera Attribute to define a U16 or a I16 for your camera, as you have it in MAX?
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
