03-11-2014 10:04 AM
I'm using Basler aca2040-180kc camera nad NI PXIe 1435. I connected the camera to the computer via PoCL (SDR to SDR) cable. When i used two cables the camera worked fine, but when i want to run it in base mode, using just one cable i get an error 0xbff60136: Cannot detect recognizable video source.
Im using LabView 2011 SP1,
IMAQ 4.7
Could anyone give me any hint on what might be causing this error and how to fix it?
03-12-2014 08:05 AM
I have a feeling that the camera is not getting enough power. Do you have a power supply for the camera? Try using that instead of doing PoCL. I believe you need both cables to power the camera using PoCL. Also, make sure the Pylon software is not being used when trying to communicate with NI software.
03-12-2014 08:14 AM
I've been struggling with this for 2 days now, and i figured out that the problem is in .ICD file which seems to be configured to use the camera in FULL mode, while i need it to work in BASE mode. The camera worked when i used .icd for Basler avA1000-120kc but it lacks some camera atributes. Unfortunatelly, i don't know how to change the acA2040-180kc icd to make it work in BASE mode
03-12-2014 08:14 AM
03-12-2014 08:20 AM
Did you try what I suggested? I've never tried making the camera work in base mode; so I'm not sure if it will.
Best thing for you to do is to contact Basler's support. They respond quickly.
03-12-2014 08:30 AM
I don't have the possibility to try powering the camera from an external source, i don't have the cable. I had the same problem before I installed pylon software, so i guess it's not the issue.
I took your advice and contacted basler support, im waiting for their response.
03-12-2014 08:31 AM
Great, please be sure to post the response here. I'm very sure that it's a power issue, and that you need a power supply if you're are not using both camera link cables.
