Machine Vision
连接Gige摄像机时出错:Error:0xBFF69012 Attribute value is out of range Attribute Name CameraAttributes::AutoFunction::AutoTargetGrayValue
操作系统:XP MAX版本:14.0 IMAQdx版本:4.3.5 摄像头:北京嘉恒中自图像OK_AC1360 生产商的应用软件中使用正常。在AMCAP软件(视频测试软件)中使用也正常。 连接Gige摄像机时出错:Error:0xBFF69012 Attribute value is out of range Attribute Name CameraAttributes::AutoFunction::AutoTargetGrayValue 试着修改 ‘AutoTargetGrayValue’ 属性值,但是MAX会无相应并死掉。
(5,338 Views)
Sometimes, camera firmware is the problem.  Sometimes, the camera XML file is the problem.  Sometimes, the way that IMAQdx tries to force settings onto the camera is the problem.
Things to try:
1. Check with the manufacturer, and ask if new firmware is available for the camera.  If the firmware cannot be updated by the end user, you will need to get a Returm Merchandise Authorization number, and send the camera in for the upgrade.
2. Edit the XML file that was downloaded from the camera, and remove all references to CameraAttributes::AutoFunction::AutoTargetGrayValue.  Do not alter, or remove the zip file that resides in the same location as the XML.  If you do, IMAQdx will request a fresh copy from the camera, and overwritew your changes.  You can find the XML file in C:\Users\Public\Documents\National Instruments\NI-IMAQdx\Data\XML
3. Edit the camera .icd file in C:\Users\Public\Documents\National Instruments\NI-IMAQdx\Data, and remove the reference to CameraAttributes::AutoFunction::AutoTargetGrayValue.
Machine Vision, Robotics, Embedded Systems, Surveillance
www.movimed.com - Custom Imaging Solutions
(5,326 Views)
Accepted by topic author kelai
Labview全部重装后还是不正常,将电脑全部重装后正常了。谢谢!
(5,183 Views)
