English Translation:
Gigabit Ethernet camera initialization is unusually slow. Using the BASLER Gigabit Ethernet cameras, the camera comes with software, but is very slow to turn on the camera in MAX, usually takes about 20 seconds, one of the 5MP camera actually used 200 seconds to complete opens. MAX is used in the program "IMAQdx Open Cameral Vi". After using the camera is normal, the frame rate and no significant loss. Is this a problem? Thank you!
Have you tried turning off any Firewalls to see if this helps?
你试图关闭Windows防火墙来看看这有助于吗?
