09-20-2007
10:44 AM
- last edited on
07-31-2009
04:23 PM
by
Christian_L
05-21-2008 10:02 PM
Hi Doug,
I would like to find out is there a way to run the simple tank demo "MC Tank Demo.lvproj" without connecting to a cRIO controller? Meaning running in simulation. If this is possible, can you teach me how to do it?
If this is not possible, may I know can this example code be run without using the exact same module? I replaced the NI-9205 with NI-9215, so the number of channel used in the original FPGA code is reduced to only 4. However, after I successfully compiled both the cie_FPGA IO and cie_FPGA Get Calibration files, I could not run the cRIO IO Engine (CIE).vi.
The reason this VI is not able to run is because the CIE functions used in this VI are all not executable due to broken arrow. I went into these function and try to manually select the FPGA Bitfiles. Unfortunately, only the cie_FPGA Get Calibration.lvbit file is successfully added into the block diagram. The other bitfile (cie_FPGA IO.lvbit) is still having a broken arrow. The error message is shown in the attachment "error.jpg".
I am suspecting the error is due to the number of AI channel being reduced when using NI-9215 instead of the NI-9205. Please correct me if I am wrong.
I would appreciate if you can send me some steps guide on how to run this example code because the resources found on the website seems alittle bit insufficient.
Looking forward to hear from you again. Thank you.
Kean Yuen
07-15-2008 06:07 PM - edited 07-15-2008 06:07 PM
KeanYuen wrote:
Hi Doug,
09-30-2009 11:11 AM
Dear Sir,
I am in need of a simple tank control reference example throguh which I can do some modifications and use the same to one of my application. I had tried in the developer zone but it is compatible with LabVIEW 2009. But I do have LabVIEW, RT and FPGA of 8.5 version. So, in this regard I request you to help me out by providing the example with 8.5 version compatible.
Thanks and Regards
Giridhar
Engineer
I-Design.
10-02-2009 09:28 AM
Hey Giridhar,
Please find the example attached. You should be able to open and modify the code in LabVIEW 8.5. I was able to get all the reference libraries to revert to 8.5 without any issue. This is because this example doesn't use the CIE.
I hope this helps!
10-02-2009 11:40 PM
08-20-2012 09:13 AM
I downloaded and installed mcatank_203_intaller.zip and all the relevant additional libraries. When I open the project I get a confict for the CVT library. In trying to resolve other issues, I may have downloaded the CVT library from more than one source. Can you tell me if the CVT library belongs in the user.lib or the vi.lib?
Thanks!
08-23-2012 01:10 PM
The CVT should be installed in user.lib.
The version that is installed in vi.lib was installed by an improperly configured VI package. In VIPM uninstall 'Reference Library for Current Value Table (CVT)'.
My Profile | Privacy |
Legal |
Contact NI
© 2011 National Instruments Corporation. All rights reserved. | E-Mail this Page
E-Mail this Page
