NI Home
Cart Cart | Help
You are here:
Reply
Member
Doug_S
PackML Machine Control Reference Application using the LabVIEW State Chart Module
[ Edited ]
Post your questions or feedback on the PackML Machine Control Reference Application here.
Message Edited by Christian L on 08-14-2009 02:56 PM
Member
stevenccc
回應: A State Chart Design Pattern for PackML Machine Control
Dear Sur:
I download PackMLV4.zip, but can not find " Copy of PackML_State_Chart.lvsc"
, PackML.test.vi and ...
Steven
Member
MarcoPolo5
Re: 回應: A State Chart Design Pattern for PackML Machine Control
The errors seen in loading the project have been fixed - this was due to some un-used VI's referenced in the project.
Version 4.1 of the code has been uploaded:
http://zone.ni.com/devzone/cda/epd/p/id/5391
Member
Pekka19
Re: PackML Machine Control Reference Application using the LabVIEW State Chart Module
The OMAC Packaging Machine Language V3.0 Mode & States Definition Document contains a description of the state machine you define in your reference application.
It states in Table 1 that the Resetting state establishes the initial state of the machine. Your controller starts in the Idle wait state and could result in a machine operating before it is safe to do so.
Is there something in the full specification that contradicts this interpretation?
Member
MarcoPolo5
I agree that the starting state should be "Resetting" - ensuring that the machine is in a stafe state on startup.
A simple modification of the statechart corrects this (see red circle) - this will make the initial state the Resetting state vs the Idle state:
Thank-you for pointing out this oversight
I will try to include this in the next version of the code
Member
GysM
PackML Machine Control Reference Application using the LabVIEW State Chart Module - files missing
There seems to be no files in the compressed "packml_v5_1.zip " file. Can someone please fix this.
Member
Daniel_E
Re: PackML Machine Control Reference Application using the LabVIEW State Chart Module - files missing
Hey,
I just tried the download and it worked for me.  Do you have a firewall or something that might strip .zip files?
Daniel Eaton
Systems Engineering
Embedded and Industrial Control
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
