Machine Control
Reply
PackML Machine Control Reference Application using the LabVIEW State Chart Module
This reference application has been deprecated and is no longer available for download.
Post your questions or feedback on the PackML Machine Control Reference Application here.
(8,669 Views)
回應: A State Chart Design Pattern for PackML Machine Control
Dear Sur:
I download PackMLV4.zip, but can not find " Copy of PackML_State_Chart.lvsc"
, PackML.test.vi and ...
Steven
(8,521 Views)
Re: 回應: A State Chart Design Pattern for PackML Machine Control
The errors seen in loading the project have been fixed - this was due to some un-used VI's referenced in the project.
Version 4.1 of the code has been uploaded:
http://zone.ni.com/devzone/cda/epd/p/id/5391
(8,251 Views)
Re: PackML Machine Control Reference Application using the LabVIEW State Chart Module
The OMAC Packaging Machine Language V3.0 Mode & States Definition Document contains a description of the state machine you define in your reference application.
It states in Table 1 that the Resetting state establishes the initial state of the machine. Your controller starts in the Idle wait state and could result in a machine operating before it is safe to do so.
Is there something in the full specification that contradicts this interpretation?
(7,615 Views)
I agree that the starting state should be "Resetting" - ensuring that the machine is in a stafe state on startup.
A simple modification of the statechart corrects this (see red circle) - this will make the initial state the Resetting state vs the Idle state:
Thank-you for pointing out this oversight
I will try to include this in the next version of the code
(7,608 Views)
Highlighted
PackML Machine Control Reference Application using the LabVIEW State Chart Module - files missing
There seems to be no files in the compressed "packml_v5_1.zip " file. Can someone please fix this.
(6,739 Views)
Re: PackML Machine Control Reference Application using the LabVIEW State Chart Module - files missing
Hey,
I just tried the download and it worked for me.  Do you have a firewall or something that might strip .zip files?
Daniel Eaton
Systems Engineering
Embedded and Industrial Control
(6,737 Views)
