Machine Control
Reply
PackML Machine Control Reference Application using the LabVIEW State Chart Module
[ Edited ]
This reference application has been deprecated and is no longer available for download.
Post your questions or feedback on the PackML Machine Control Reference Application here.
Message 1 of 7 (8,578 Views)
Reply
回應: A State Chart Design Pattern for PackML Machine Control
Dear Sur:
I download PackMLV4.zip, but can not find " Copy of PackML_State_Chart.lvsc"
, PackML.test.vi and ...
Steven
Message 2 of 7 (8,430 Views)
Reply
Re: 回應: A State Chart Design Pattern for PackML Machine Control
The errors seen in loading the project have been fixed - this was due to some un-used VI's referenced in the project.
Version 4.1 of the code has been uploaded:
http://zone.ni.com/devzone/cda/epd/p/id/5391
Message 3 of 7 (8,160 Views)
Reply
Re: PackML Machine Control Reference Application using the LabVIEW State Chart Module
The OMAC Packaging Machine Language V3.0 Mode & States Definition Document contains a description of the state machine you define in your reference application.
It states in Table 1 that the Resetting state establishes the initial state of the machine. Your controller starts in the Idle wait state and could result in a machine operating before it is safe to do so.
Is there something in the full specification that contradicts this interpretation?
Message 4 of 7 (7,524 Views)
Reply
Highlighted
I agree that the starting state should be "Resetting" - ensuring that the machine is in a stafe state on startup.
A simple modification of the statechart corrects this (see red circle) - this will make the initial state the Resetting state vs the Idle state:
Thank-you for pointing out this oversight
I will try to include this in the next version of the code
Message 5 of 7 (7,517 Views)
PackML Machine Control Reference Application using the LabVIEW State Chart Module - files missing
There seems to be no files in the compressed "packml_v5_1.zip " file. Can someone please fix this.
Message 6 of 7 (6,648 Views)
Reply
Re: PackML Machine Control Reference Application using the LabVIEW State Chart Module - files missing
Hey,
I just tried the download and it worked for me.  Do you have a firewall or something that might strip .zip files?
Daniel Eaton
Systems Engineering
Embedded and Industrial Control
Message 7 of 7 (6,646 Views)
Reply
