MATRIXx
user code block
I have a model which includes a user code block.  I can simulate the model within MatrixX and it compiles OK but when I try to run the model on the target, it won't run.  Can you offer any advice?
(7,990 Views)
Hello Jim,
Can you please post some more specifics about the behavior you are seeing?  From your post it appears that you are able to build and run code that does not include a user code block?  What version of MATRIXx are you using?  What exactly happens when you try to run your code?  Do you see any errors, crashes or incorrect data?
Thanks, we will be able to provide a little more guidance when we know more about how your application is failing.
Angela M
(7,980 Views)
