08-16-2007 06:09 AM
Hello
i have some problems with getline under Matrixx 7.17 - windows xp
Calling getline und typing something into the line produces an output like:
plot2d_cb "on_click_border", "MainWin",3;
The input of the user is ignored.
This problem only occures when getline is used in a function together with plot2d.
Is this problem known? What can i do to fix this bug?
Ralph
08-16-2007 10:09 AM
i just build an example to document the problem:
Execute getlinetest.ms
File getlinetest.ms
erase {logarea}
display("This Script will show the problems with getline and plot2d")
display("plot2d seems to send his output to getline....")
pause ""
out=getlinetest_in_function(2)
File getlinetest_in_function.msf
function out=getlinetest_in_function(def_zahl)
plot_win_ampsec1=33
plot_win_ampsec2=34
time_vek=[0:0.01:10]'
y1=[sin(time_vek),cos(time_vek)]
y2=[cos(time_vek),1+cos(time_vek)]
y3=[cos(time_vek),sin(time_vek)]
y4=[-sin(time_vek),-cos(time_vek)]
y5=[-sin(time_vek),cos(time_vek)]
y6=[sin(time_vek),-cos(time_vek)]
plot2d(1,2,{win=plot_win_ampsec1})
plot2d({win=plot_win_ampsec1,destroy=1})
plot2d(1,2,{win=plot_win_ampsec2})
plot2d({win=plot_win_ampsec2,destroy=1})
counter=1
counter_max=20
idx_choice=[]
while out(1)<>0 & counter<counter_max
display("######### Next Trial ##########")
# first window
plot2d(time_vek,[y1],{keep=0,title="az vr", grid,xlab="t[s]",ylab="y1",nr=3,nc=2,r=1,c=1, win=plot_win_ampsec1})
plot2d(time_vek,[y2],{keep=1,title="az vl", grid,xlab="t[s]",ylab="y2",r=1,c=2,win=plot_win_ampsec1})
plot2d(time_vek,[y3],{keep=1,title="az hr", grid,xlab="t[s]",ylab="y3",r=2,c=1, win=plot_win_ampsec1})
plot2d(time_vek,[y4],{keep=1,title="az hl", grid,xlab="t[s]^2",ylab="y4",r=2,c=2, win=plot_win_ampsec1})
plot2d(time_vek,[y5],{keep=1,title="w_2dot",grid,xlab="t[s]",ylab="y5",r=3,c=1, win=plot_win_ampsec1})
plot2d(time_vek,[y6],{keep=1,title="n_2dot",grid,xlab="t[s]",ylab="y6",r=3,c=2, win=plot_win_ampsec1})
# second window
plot2d(time_vek,[y1],{keep=0,title="az1 vr", grid,xlab="t[s]",ylab="y1",nr=3,nc=2,r=1,c=1, win=plot_win_ampsec2})
plot2d(time_vek,[y2],{keep=1,title="az1 vl", grid,xlab="t[s]",ylab="y2",r=1,c=2,win=plot_win_ampsec2})
plot2d(time_vek,[y3],{keep=1,title="az1 hr", grid,xlab="t[s]",ylab="y3",r=2,c=1, win=plot_win_ampsec2})
plot2d(time_vek,[y4],{keep=1,title="az1 hl", grid,xlab="t[s]",ylab="y4",r=2,c=2, win=plot_win_ampsec2})
plot2d(time_vek,[y5],{keep=1,title="w1_2dot",grid,xlab="t[s]",ylab="y5",r=3,c=1, win=plot_win_ampsec2})
plot2d(time_vek,[y6],{keep=1,title="n1_2dot",grid,xlab="t[s]",ylab="y6",r=3,c=2, win=plot_win_ampsec2})
# idx_choice=getchoice("Select something or not",["Topic1","Topic2","Topic3","Topic4","Topic5"],{multiple,default=[idx_choice]})
display("Now Click into both plot2d-Windows")
out=getline("Click into both plot2d-Windows. Exit with 0!")
display("Output of getline:")
display(out)
display("End of Output of getline:")
errorflag=index(out(1),"plot2d_cb")
if errorflag<>-1 & errorflag<>[]
beep
pause "look to the output of getline"
pause "This problem occures not only when you click on a window"
pause "Somtimes moving of a plot2d-Window will produce also the error"
endif
out=makematrix(out)
counter=counter+1
endwhile
if counter>=counter_max
display("We finish")
endif
endfunction
08-20-2007 06:24 PM
08-21-2007 02:32 AM
Hi Dirk
thank you for your answer.
Can you give me a hint to get an alternativ to getline?
An upgrade to 8.0 is not possible at this time, because i would have to check more than 600 programs and i dont have the time for this now.
If there would be a workarround for getline this would solve my problems for the moment.,
Ralph
