The Microsoft Visual Studio compiler may not configure the necessary environment variables when it is installed. This must be done manually. Microsoft VisualStudio has a script to setup the environment. It is called vcvars32.bat and is located in \VC98\bin.
There are two ways to set up the environment. The second method is recommended.
The first way is to set the environment variables every time Xmath is started from a new DOS window. To do this open a DOS command prompt from the start menu in Windows. Then run vcvars32.bat. After running the batch file, start Xmath from the same command prompt. If you start Xmath from the start menu or a desktop shortcut the environment settings will not have been applied for that session. The environement changes only apply to th
e currently opened DOS shell. Other DOS shells are unaffected, so the process must be repeated.
The second way is to change the environment settings in Windows. On Windows NT, 2000 or XP
1. Open Controls Panels from the start menu.
2. Select System Properties.
3. In the System Properties dialog box select environment variables.
4. Enter the variables as defined in vcvars32.bat into the variable and value fields.
Joe D.
