06-22-2008 07:19 PM
06-24-2008 03:02 PM
Let me first discuss about comparing models, then I'll talk about my ideas about modularization.
Comparing models in anything before v8 is difficult. In v6 or v7, there's no way to load to separate files containing the same yet different superblocks. The tool scripts you found don't seem to be documented anywhere. Given the history of some of the things added into the product, I'm not surprised. Which means that it's useless to us. After looking at the scripts, it's difficult to figure out what the inputs to that script should be. You can launch multiple instances of xmath/sysbld and load the models separately, but that's about it.
One suggestion if you have to compare models is to use the exportcatalog.msc script which will generate a text file containing the SBA commands to re-create the model. Do the same for both models then perform a text difference between the generated SBA commands in the generated files.
Another possibility is to use SBA to get the details of each superblock (similar to exportXXX.msc scripts) into a form that's easier to compare between. I'm going to guess that some kind of generated SBA content is the expected input to the compare_catalogs, but I'm not sure.
Now, within v8, we've created a hierarchical compare tool, that compares model files and shows differences. Copying changes between the compared models is a future enhancement. However, in the context of using v8, you could manually copying the changes between the models using the editor and/or project system as appropriate. Yes, in v8 you can separately load models containing the same named superblocks. Try it, I'll bet you'll like it and it will save you lots of time!
Now, on to modularization. I'm not sure you're use of 'components' is the meaning of the Components feature in Sysbld or not. I'm going to assume that you are not using Components and you're generically using the term components as a set of logically related superblocks, or as I perfer to call them, a module.
The only modularization tool you have in Sysbld is the file. What I mean here is that you are able to group sets of superblocks into separate savefiles (.sbd) then combine them to create a complete model. So, essentially, you will need to partition your model into modules and each module is a separate savefile. Then, you can choose which module (i.e. savefile) to load to construct a complete model.
In v8, there's a project system specifically designed to make this kind of modularization within a project easy and straightforward to use and maintain. I'd suggest that you use v8.
For previous versions, the best you can do is create xmath scripts for each complete model you need. The script will contain all of the steps needed to load the separate modules to make a complete model. Thus, you'd have a different script for each model. Also, becareful in v6,v7 that you'll have to manually manage which superblocks are part of which modules, it's tricky stuff. Again, you'll need to use scripts to help maintain this level of complexity in these versions of the Sysbld.
Now, I do not want to recommend FileSuperBlocks, it's a legacy feature to deal with limited resources not applicable on today's machines.
Also, I can't really recommend the the Component feature in Sysbld. It's really not a component, but more of an object, sort-of. And it sort-of gives you unique names and it sort-of gives you parameters. It will not help with the modularization I think you want so don't use these.
In general, there are features within our latest v8 release of MATRIXx that will help you with all of your issues. If you can, upgrade!
Bob Pizzi
MATRIXx R&D
06-25-2008 07:00 AM
