NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
andreasse
Accepted Solution
***W*** No symbol(s) found
What does this warning mean?
load file = "mysbdfile.sbd"
`load' file = "c:\mysbdfile.sbd"
mysbdfile.sbd is a Signal Build Model with User Code Blocks.
Andreas
Active Participant
OliviaC
Re: ***W*** No symbol(s) found
Hi Andreas,
This warning has come up before when there are no variables in Xmath. Is this the case with you?
Member
andreasse
Well, there was no variables in Xmath, but trying to define some and calling the same command (open file = ...) doesn't seem to affect it, I still get this warning. It seems to depend on which file I choose to load, but I can't figure out what this warning really means...
It might depend on which function name the User Code Block calls in some way...
Andreas
Member
andreasse
I'll post the answer I've got from the support, if someone else also would like to know
> The "*** W *** No symbols(s) found" is just a warning since the open and save command expect variables to be in the file.
> The warning is to let you know that nothing was changed in Xmath.
> To remove the warning, add {build} to the end of the open or load command to indicate you only want to load SystemBuild data.
Andreas
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
