MATRIXx
Procedure for Upgrading Previous Versions of Matrixx to V8
I'm in the process of upgrading Matrixx v4.1 to v8.   Looking for any guidance as to steps invovled.  (model changes,  Code Template modifications etc.)
(9,509 Views)
Hello TB1,
This sounds like quite a jump in versions you are making, do you have any of the versions inbetween?  I would recommend reading the release notes and what's new sections of the help for each of these versions.  I don't know that anything was removed, but I am not familiar with the version you are coming from.  There were a lot of UI changes for version 8, so it is probably worth while to review the Getting Started document also to familiarize yourself with the new environment.
I hope this helps, good luck with your upgrade.
Angela M
(9,502 Views)
Hello TB1,
If you are still monitoring this forum you can email matrixx@ni.com for more help.
Angela M
Product Support Engineer
(9,473 Views)
