____________________________________
Hi Bosco,
If you want to trigger an Expression with just the LoLo Alarm, and not the other states of this very same alarm (Lo, HiHi, etc.), then you will have to use an Alarm Object to configure your Alarm first. This is because the $Alarm global object does not have the granularity of individual states of the Alarm, i.e., LoLo, HiHi, etc. $Alarm only has Alarm.active member.
Once you have created an Alarm object, you can then have an Expression like this:
if(Alarm1.lolo,"Transmitter Bad","Transmitter Good")
or
if(Alarm1.lolo,"Transmitter Bad"," ")
Where Alarm1 is the Alarm Object and the 'false' result may have a NULL.
Hope this helps,
Khalid 🙂
