Lookout
onchange number
Dear Experts, I would like to monitor change of and number data (ex text entry value) an generate boolen signal on change, please help me how can I do. Regards, daneshy
(5,156 Views)
There is no pre-built or perfect solution.
Forshock - Consult.Develop.Solve.
(4,910 Views)
So bad!
any other solution?
(4,788 Views)
Create: Pot1
Create: Expression1 = Pot1
Create: OneShot1 - Pot1!=Expression1
Edit: Expression1 - Trigger=OneShot1
OneShot1 is the onchange event. Make duration as long as necessary or desired
(4,777 Views)
Are you wanting to use the "onchange" to perform some logic or just record the event to the event logger? If you want to perform something Mikes solution looks good. If you are just looking to know that someone changed a pot or text entry won't the event check box work?
Jim
(4,749 Views)
