I remember seeing maybe a new mailer .cbx file was available that had the ability to change the outgoing port number from the default of 25 to another port #. I am using Lookout 6.6 but don't see a way to do this. Is there a fix for this? And is NI going to ever address the problem of authentication required and SSL for the mailer? Just telling people to use an SMTP server that doesn't require authentication isn't really a solution, many ISP's don't allow third party servers to be used.
I need the port change for version 6.0.2. As far as the SSL is concerned, the ISP's mail server is SSL. This particular ISP does not allow the use of third party servers (many ISP's do not) so just changing mail servers is not an option.
