Reply
email port number change
I remember seeing maybe a new mailer .cbx file was available that had the ability to change the outgoing port number from the default of 25 to another port #. I am using Lookout 6.6 but don't see a way to do this. Is there a fix for this? And is NI going to ever address the problem of authentication required and SSL for the mailer? Just telling people to use an SMTP server that doesn't require authentication isn't really a solution, many ISP's don't allow third party servers to be used.
Message 1 of 5 (3,024 Views)
Reply
Re: email port number change
Ryan can you email me the mailer object that has port # change? email is mjrx@comcast.net This would be for version 6.0.2
Message 2 of 5 (3,016 Views)
Reply
Do you want 6.6 or 6.0.2? This feature has already been added to 6.6. Create a mailer.ini file with below content
[All]
SMTPport=25
Ryan Shi
Message 3 of 5 (3,007 Views)
Reply
Highlighted
The authentication is supported in 6.6, but the SSL is not supported. Is it necessary for you to use a mail server that requires the SSL?
Ryan Shi
Message 4 of 5 (3,006 Views)
Reply
I need the port change for version 6.0.2. As far as the SSL is concerned, the ISP's mail server is SSL. This particular ISP does not allow the use of third party servers (many ISP's do not) so just changing mail servers is not an option.
Message 5 of 5 (2,996 Views)
Reply
