Lookout
Verify Modem connection thru ASCII Object
How get i the CONNECT RING and NO CARRIER Message from a modem to the RESPONSE Frame of teh Ascii Object. Well, my dialup connection still works but i am not able to verify the line. Sometimes the modem transfers trash.
(2,685 Views)
The response data member of the ASCII object gives the "Exact response frame received." So if it is not giving you the no carrier signal, then the modem must not be relaying that information.
(2,685 Views)
