Lookout 4.5 and 5.0 support ActiveX controls but just the (main) properties are showing up as datamembers.
It is not of the concept of Lookout's datamember/event architecture to create in a easy way customed events to invoke some methods of an ActiveX control. Thus, National Instruments does not support those ActiveX methods (neither ActiveX events). The only way it could encounter both, the datamember model with Lookout's internal event handling and the ActiveX event functions, would be to create a wrapper ActiveX control with special, new properties that would invoke the methodes in the original ActiveX control.
National Instruments has a nice documentation how to write an ActiveX control for Lookout. But it requires to have the Lookout Object Development
Toolkit, to be able to download this additional documentation with examples.
If you are interessed you can get more info from this link:
http://digital.ni.com/softlib.nsf/websearch/26166A48F59026A986256BBC0053AAFD?opendocument&node=132070_US
Hope this helps
Roland
