08-10-2015 08:58 AM
Dear Expert,
I am using SQlEXEC in order to iunsert some data to an SQL data base, but unfortunetly this error accured.
[Not Buffered] 28000/18456: [Microsoft][ODBC SQL Server Driver][SQL Server]Login failed for user ''..
P.S: i can use same OBDC DSN with othe applicatiopn.
Danesh
08-13-2015 04:16 AM
It sounds like a problem about your ODBC SQL Server access permission. Could you check that first?
08-13-2015 10:21 AM
08-14-2015 03:44 AM
I suggest that you should send your code to lookout.support@ni.com, and the expert there could help to solve your problem.
