09-02-2010 02:11 PM
I'm getting the message "You have a higher version of NI Uninstaller in your system" when I was trying to re-install Lookout 6.1 after installing and uninstalling Lookout 6.5.
The error says for me to uninstall the higher version of NI Uninstaller? Where and how do I do this?
Max
09-03-2010 03:42 AM
Please give a screenshot of the error you got.
Actually you should be able to install 6.1 even if you don't unistall 6.5.
Are you able to install 6.5 now?
09-03-2010 11:20 AM
I'm running Windows 7 Professional (64 bit)
1) This is the error I get when installing Lookout 6.5
I then select "Yes" to continue, choose "evaluation mode" and let it complete the install, restart computer and run Lookout 6.5.
But Lookout 6.5 does not run and I get the following error:
2) Now I try and install Lookout 6.1, the part where it is initializing the installer completes and I click on "Next"
I go through with the information input for user/company/serial, select complete install, license agreement and then click next and I get the following error:
And now I am at the problem.
So I click on Yes (to continue) and I get the following error:
and I continue and get the next error
and so on...
Thanks for your help. I'm almost short of formattimg the drive and reinstalling the entire system but I'm hoping it's just a minor item that was overlooked.
09-06-2010 03:03 AM
Did you unistall lookout 6.5 from Control Panel? I'm trying to figure out the NI-PAL install error.
But Lookout 6.1 doesn't support Windows 7.
09-07-2010 12:03 PM
I uninstalled "National Instruments Software" from the Control Panel:
-after clicking "Yes", some components are installed and the window closes.
- I then restart the computer.
- After the computer restarted I went back to the Control Panel and saw that "National Instruments Software" was still shown. So I selected it again to uninstall. I got the same prompt as above and when I clicked "Yes' the "Shared Components Detected" panel closed without any sign of uninstalling the components.
- I go to the start menu and see that Lookout 6.5 is still in there. I click on the Lookout 6.5 icon in the start menu and I get the following panel:
Looks like Lookout 6.5 is not completely uninstalled.
Lookout 6.1 worked on Windows 7. All I did was install Lookout 6.5 after uninstalling Lookout 6.1.
09-07-2010 02:33 PM
Okay I got past a big hurdle with the install...but still have problems running Lookout 6.1
I went into the registry..........HKEY_CLASSES_ROOT\Installer\Products\ and deleted anything NI related and that seemed to work in removing the NI Uninstall message I get when trying to install Lookout 6.1.
1) I managed to get past the "uninstall the NI Uninstaller" during the Lookout 6.1 install process but near the end ran into the following:
I selected "yes" to continue and it completed. I rebooted the computer and ran the Lookout 6.1 executable and got the following error:
Wondering how I can get past the Lookout 6.1 install error.
09-08-2010 08:52 AM
If Lookout 6.5 is installed correctly, when you choose to unistall it from control panel, you will see a pop-up dialog box for you to choose which product to unistall or change.
As for the NI-PAL error in install, do you logon windows as Administrator or have Administrator privilege?
If you are not Administrator, take a look at the security property of the System32 folder. Maybe you don't have the permission to add files to the system32 folder.
09-10-2010 11:34 AM
I've given up on making it work and have just reinstalled Windows 7 and everything is working again.
Ryan...thanks for your help.
03-06-2015 08:03 AM
first come easy . I have difficulty in establishing the lookout 6.6 scada software helps me Do
