Lookout
OPC Client Question
I am having a problem getting OPC up and running. The server configured OK, I can see all my tags. When I run the the Quick Client from the server everything looks OK, data quality is listed as good, I can see all my tags and see live data values changing from my PLC (CompactLogix). The problem is when I try to access the server data from Lookout. I setup OPC Client, see the NIOPC server in the drop down, select it, but when I look at OPCClient1 in the Object Explorer there are some objects and folders there, but my server configured "Channel1" & "Device1" do not appear in the tree, so there is no data to look at. Anyone have any ideas about what this could be? Running version 6.6
Message 1 of 1
(4,462 Views)
