It seems your question is made up of three parts:
1) How do I parse (break into its constituent components) Lookout's system time?
2) How do I convert this time into a hexadecimal format?
3) How do I write these values to my instrument from Lookout?
I am not familiar with Modbus but I am proficient in data conversions in Lookout. So, maybe I can help?!?!
Question #1 is already answered with example files. Do a search in this message board for "Time Clock". There you will find your answer to parsing Lookout's time into decimal format and outputting the values to pots, or any datamember of a Lookout object for that matter.
Question #2 is answered with example files also. Do a search in this message board for "hexadecimal conversion". There you will find the answer to converting decimal values to hexadecimal.
As for question #3: You are , obviously, using Lookout's Modbus driver. This object has datamembers you can connect the output of your yet to be built "time parser/hex conversion/update" Lookout code. Your question above says the documentation refers to register 0002 as the date and time register. This register, in all likely hood, is equivalent to the datamember 0000002 in Lookout's Modbus driver object. This is what you would connect the output of your "time parser/hex conversion/update" code to. Your example gives HEXadecimal(005D 0714 0B05 1234) = DECimal(0093 July20 11Hours05Minute 4.660seconds)- You said 1993 but I assume you mean 2093. As the final result of my code I would have 4 expressions evaluated as text ( your 4 output words above). I would concatenate the 4 text expressions with each other using the "&" operator . I would then concatenate this text expression with "0x" using the "&" operator. The 0x tells Lookout this is a hexadecimal value. Now connect this expression to the datamember 0000002. Since Lookout supports data polymorphism this may very well work.
Remember: This is only an idea. I am not experienced with Modbus so proceed with caution. I hope this does get your creative juices flowing!
Tommy Scharmann
