Lookout, for the simple purpose of acting as an OPC server is very easy to configure. However, this procedure will only work with a developement version of Lookout.
First start Lookout and open a NEW process. Next, go into edit mode and create a Modbus object (Object>>Create). Configure the Modbus driver according to your specific system requirements. Click OK on the Modbus object properties panel. Finally, save this process by going to File>>Save As.
At this point, Lookout is ready to act as an OPC sever and allow you to access the Modbus driver through an OPC/Datasocket connection. This Lookout process must, however, remain running to continue this functionality.
For more information, please review the valuable information found in the Lookout Online Help which
was installed with Lookout. There you will find tours, tutorials, examples, and reference materials that are vital to understanding Lookout.
Chad Pelletier
Applications Engineer
