Lookout
MAX does not display alarms generated with lookout 6.6
Hi guys,
This is the first time I use lookout 6.6. I compiled a project developed in lookout 6.5.
During the installation of lookout on an XP SP3 platform, the phase that install and configure Microsoft SQL run well, but when I try to display the historical of alarms in MAX, after the refresh command, no events are displayed.  I check if the services are running. During the exploration an error windows appears with the message "MMC has detected an error in a snap-in". Note: the trace views works correctly.
I detached the current database and create a new one. I check that the process links to the correct database. The alarm and event view is still empty. It seems that the events are not logged in the database. I search in Microsoft knowledgebase, but the informations are not clear (they talk about windows server and not on XP).
Do you know something to do?
Mario Fanelli
(5,848 Views)
Hi there - were you able to find a fix to this issue?  I am having exactly the same problem.
(4,850 Views)
Check the log on tab into the SQL Server (CITADEL) service if the "Log os as"  has the "Local system account" selected.
(4,841 Views)
