03-22-2012 04:55 PM
When starting a process in Lookout 6.5 it takes a very long time to load (if it does). In order to start the process file I have to close my OPC Server (AB OPC by Ingear). What might be causing the problem?
03-25-2012 08:21 PM
Copy this ini to lookout folder, and start that process. Wait until the process is loaded(if it can be loaded). The opc communication will be logged. The log file path is set in the ini file. File name is the opc client object name.
If you close OPC Server, start Lookout, and then start the OPC Server, will it work?
