Lookout
Lookout drivers for Allen Bradley
Is there a driver I can Use for The Allen Bradley CompactLogix L32E Ethernet communication
Message 1 of 8
(5,890 Views)
I am currently facing the same issue.  I think you need to map the address to PLC5 or SLC 500 and then I believe you can use AB ethernet driver.
I will not be tackling mine for another month or two but is on my upcoming project list.
Message 2 of 8
(5,877 Views)
Kepware was an OPC driver that works well with Lookout.
Message 3 of 8
(5,875 Views)
I was just looking at the NI opc server that we have in our load. And it does appear to support compactLogic.
NI opc = kepware as far as I know
Message 4 of 8
(5,873 Views)
Kepware is an OPC server.  You would use the OPCclient object in Lookout.  Lookout -> OPCclient -> Kepware -> L32E.
Message 5 of 8
(5,871 Views)
i tryed that but will not work on eithernet
Message 6 of 8
(5,854 Views)
Kep ware at 900.00 a per screen
Message 7 of 8
(5,838 Views)
One thing you can do is map the tagbased data out to Allen Bradley orginal tag conventions.  We have done that with some of our HMI's.  I have not tried this with Lookout yet but will be starting this in the up coming month.
Message 8 of 8
(5,834 Views)
