03-24-2014 09:10 AM
Is there a driver I can Use for The Allen Bradley CompactLogix L32E Ethernet communication
03-25-2014 11:31 AM
I am currently facing the same issue. I think you need to map the address to PLC5 or SLC 500 and then I believe you can use AB ethernet driver.
I will not be tackling mine for another month or two but is on my upcoming project list.
03-25-2014 11:39 AM
Kepware was an OPC driver that works well with Lookout.
03-25-2014 11:47 AM
I was just looking at the NI opc server that we have in our load. And it does appear to support compactLogic.
NI opc = kepware as far as I know
03-25-2014 11:53 AM
Kepware is an OPC server. You would use the OPCclient object in Lookout. Lookout -> OPCclient -> Kepware -> L32E.
03-26-2014 10:20 AM
i tryed that but will not work on eithernet
03-28-2014 07:13 AM
Kep ware at 900.00 a per screen
03-28-2014 09:25 AM
One thing you can do is map the tagbased data out to Allen Bradley orginal tag conventions. We have done that with some of our HMI's. I have not tried this with Lookout yet but will be starting this in the up coming month.
