10-20-2016 11:45 AM
I am currently running Lookout version 5.0 and version 6.1 on one server. My question is, Can I install version 6.7.1 on a server that is already running version 5.0, compile the source file of 5.0 and rebuild in version 6.7.
Thanks In advance
10-21-2016 12:39 AM
So do you mean you want to use two versions of Lookout in computer?
10-22-2016 05:45 AM
Yes.. version 5.0 and Version 6.7.1. Use both until I build new screens in 6.7 then will remove 5.0
10-23-2016 08:24 PM
Hi, yes, you can use both version 5.0 and Version 6.7.1 on the same computer, you can create the process using version 5.0 and then build it in 6.7. But you cannot open the two software at the same time.
10-24-2016 05:42 AM
Thank you for the reply.. I can open and run 5.0 and 6.1 at the same time on my server, Can you tell me what happens when you open 5.0 and 6.7.1 and run together?
10-24-2016 08:16 PM
It seems that only one version of Lookout can be opened at one time, that means when Lookout 5.0 is opened, you cannot open Lookout 6.7.1, and when you open Lookout 6.7.1, you cannot open Lookout 5.0.
10-25-2016 08:25 AM
Must be restrictions on operating systems and or hard drive space. I can and do rum 5.0 and 6.1 now.
I am just trying to verify 6.7 will run with 5.0 without complications
10-26-2016 04:01 AM
Could you tell me some information of your system and computer configuration?
10-26-2016 05:41 AM
I am running Server 2003 with multiple hard drives. I can open and leave running 5.0 and 6.1 at the same time with no issues.
10-26-2016 08:23 PM
Hello, Lookout 6.7.1 can only be supported by Windows Server 2003 R2 (32-bit) and also has the following minimum system requirements:
I don't know if you OS belongs to R2 edition, if your system can meet the above requirements, you can installed Lookout 6.7.1 in the system.
Generally speaking, the two versions can be intalled in one computer, but not recommended.
