09-27-2016 03:16 PM
We run lookout for our plater. Each bar on our plater has an excel document that is written to from lookout. Our excel documents are as follows: bar01, bar02, bar03 ect... For some reason it skips bar 63 and goes to 64. How do i setup in lookout to export the data from bar63 to an excel document like the others are doing? I hope i am explaining it correctly.
Thank you
09-29-2016 12:35 AM
09-29-2016 07:55 AM
I didnt set it up origanaly but it looks like that channel was never setup. How do i set it up?
Thank you
09-30-2016 12:19 AM
10-05-2016 07:54 AM
I can not find any of these setting in lookout at all. Can you explain where i can find these settings? I dont see the menus your talking about
10-08-2016 01:02 AM
On the premise that Lookout (Development/Runt-Time) has been installed in your computer, you can open your source file(your .lks file) directly, then click Edit->Edit Mode to skip to edit mode, in this case,you can see the Object Explorer Window, if it is not shown, click on Object-> Object Explorer, the window shows up, then you can edit code according to the steps.
