Problem: When I convert a 3.8 Program to 4.5, I have about 60 Pots (the example below is a basic example of the Pot) that should change to a value of 1 when pb1 is pushed and 2 when pb2 is pushed, otherwise it retains its current value. With 4.5 about ? of these 60 pots will change value as long as the Pb1 or Pb2 buttons is pushed. When the button is released the pot will go back to its previous setting.
Is it correct in 4.5 to have a pot look at itself? I get the same results if I use the native 4.5 Pot or the Pot38.cbx with the remote settings.
Ie.
V3.8
Pot1 Remote setting:
Nif(pb1,0,nif(pb2,1,Pot1))
V4.5 (using the Pot38.cbx)
V4.5
Pot1 Remote setting: None
Valu
e= Nif(pb1,0,nif(pb2,1,Pot1))
