NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
Ravinder
LookOut driver for Allen Bradley 1784 - PKTX Card
Has the driver for Allen Bradley 1784-PKTX been included in the latest version of LabVIEW LookOut Protocol Driver ?
Active Participant
Ryan.S
Re: LookOut driver for Allen Bradley 1784 - PKTX Card
The NI OPC Server supports PKTX card. It is shipped with DSC 8.5 or higher and can only be used with DSC 8.5 or higher. But it is not included in Lookout. We will probably add this to Lookout in the future but the current version doesn't support it.
Ryan Shi
Member
SCADADog
The last post is dated 2008.  Are there Allen-Bradley 1784-PKTX drivers available for Lookout V6.6?
Active Participant
Ryan.S
The NI OPC Server shipped with lookout 6.6 supports the 1784-PKTX card.
Get the Lookout 6.6 evaluation software
http://joule.ni.com/nidu/cds/view/p/id/2620/lang/en
Or you can test the NI OPC Server directly
http://sine.ni.com/nips/cds/view/p/lang/en/nid/204755
Ryan Shi
Member
SCADADog
I have Lookout V6.6 and see that the NI OPC Server Runtime was loaded when I installed Lookout.  If I understand correctly, I have to use the NI OPC Server to communicate with the A-B DH+ board and cannot make a direct connection to the board through Lookout via a driver.  Is this correct?
Assuming this is correct, do I need to purchase additional SW to use the NI OPC Server for my project?
I have not used the NI OPC Server before.  Is there a tutorial on NI's website anywhere?
Thanks for your help.
Active Participant
Ryan.S
The NI OPC Server license is included in the Lookout license. So, you don't need purchase additional software if you have Lookout 6.6 activated. I think the help of NI OPC Server give you a brief introduction of how to use it. You need to create a channel, device and then add tags. After you configure the NI OPC Server, you can use the Quick Client tool to test the communication. The Quick Client is part of NI OPC Server. If you see value updating in Quick Client, it means the driver works. So you can add OPClient object in Lookout to connect the NI OPC Server.
Ryan Shi
Member
SCADADog
Thanks Ryan, this should get me heading in the right direction.
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
