11-19-2013 10:42 PM
LKS is the source file of the process you are working on, saved in same folder as process.
Right click the ascii object, select Edit Connections.
"ResponseFormat" is what formats the frames coming across the serial line.
11-20-2013 11:05 AM
Mike,
Here is the LKS file. I also attached a screenshot of the response format screen - I don't believe there is anything selected for the response format data member. Or am I just missing it?
Jared
11-22-2013 11:34 AM
Is there a way in Lookout to concatenate a certain number of digits to join what I need together?
Jared
11-22-2013 01:26 PM
That is what I was going for, but the problem is that from what it appears you string may not always be 5 (or x) characters.
Let me play with the source you provided a little bit and give you something to try.
11-22-2013 01:36 PM
11-22-2013 01:48 PM - edited 11-22-2013 01:49 PM
Okay, on Ascii1 set ResponseFormat to "M%f"
Drag the ascii1.RSV1 value to the display. (you are currently showing ascii1.response)
Any luck?
EDIT: Ascii1 may actually need to be Ascii2 for my test.
11-22-2013 04:56 PM
11-22-2013 05:31 PM
It looks like "ASCII2" is the weight scale?
If so, set the responseformat on that one. It should go into the RSV1 datamember.
11-22-2013 05:41 PM
11-22-2013 05:44 PM
Okay, whatever one you are trying to get 😉
It starts with "M", eg "M31.13" from your example spreadsheet.
