Hi Roland,
I'm sure you are right - there must be a bug in
aggregate object of Lookout. I came across this
problem twice in a couple of days. Lks were correct
and recompiling didn't help. I had to make a 'clean'
Lookout reinstall to get it fixed up.
Moreover it seems there are several bugs in aggregate.
For example, with nested aggregates linked like
Main.Aggregate1->Sub1.Aggregate1->Sub2, if
Sub2 contain customs graphic then Main will display
wrong customs graphic, though all of .lks are correct.
I tested this with Lookout 4.5.1.18 on Win98
and Win2000 - the bug is evident in 100% cases.
I already reported this problem to NI and I sent
them my sample files along with screenshots showing
wrong graphic display.
Meantime, it would be interesting to test this
ag
gregate behavior with other Lookout versions/builds.
Would you like to take a look at my files?
Sergei
Roli wrote:
> Hi Sergei
> this looks like it is a bug in the aggregate part of Lookout. I would
> recommend to send all your information (aggregate process files, your
> process file, ini files, drwatson.log file)... to www.ni.com/ask or
> you contcat National Instruments support.
> If National Instruments cannot locate the error it is maybe a
> corrupted process file you've got when you saw the crash. In this case
> recompiling the *.lks files might help. Or you ask again NI for help.
> Regards
> Roland
