In Serial Port Setting Com 1 set up for Hardwired and Com 3 set up for dial up the settings will not allow separate com ports Set up ports but the settings will have both the hardwired and dial up using the same com port.
In the Serial Port Setting I have Com 1 set up for Hardwired and Com 3 set up for a dial up modem. Problem is the settings will not allow me to use the different com ports. When I set up the com ports accordingly the settings will have both the hardwired and dial up using the same com port. Hope this explanation makes sense.
