NI Home
Cart Cart | Help
You are here:
Reply
Active Participant
erblock
IPASCII Object is Broken
I hadn't used this object since Lookout 6.1 and when I went to code use of it today, I discovered that it is broken in Lookout 6.6 and 6.5 as follows:
For both versions of the .cbx, only RequestFormat, ResponseFormat, RQVx, RQVx.logical, RQVx.txt and Send data members are exposed for connections.  The RSVx series is not available, making the object useless.
cbl.exe will compile IPASCII source code with the hidden data members but then Lookout crashes when opening the file.
I looked back at some clean 6.5 installs and IPASCII has the same problem in that version.
Can you please fix this ASAP?
Ed
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
