Assuming your Ethernet instruments use simple ASCII commands, you can try using the IPASCII Object in Lookout.
With the IPASCII Object, you can communicate with any device that transmits and accepts formatted strings of ASCII data via the TCP/IP, UDP, or IP protocol. See the Online help for more details.
Rgds,
Khalid
