08-24-2016 07:36 AM
Hello, I am using the LOOKOUT version 6.0.2. I need to turn the Hypertrend "upside / down" in other word, I need to have zero point (0%) in the top and the 100% at bottom. Is that possible? Perhaps not in my, version but can a newer version do this?
Solved! Go to Solution.
08-26-2016 01:33 PM
So, you wnat to invert the graphic representation of every pen....
Try this: Go to every item of the HiperTrend and set to 100 all Numerical minimum or Logical base position, and then put a "-" sign in front of all Numerical maximum or Logical TRUE height.
That should do it.
08-30-2016 09:05 PM
