Please be more specific.
If you wish to get to the alarm information, the $Alarm subsystem has many parameters you can get data from about the active alarm.
If you wish to gain numerical data about the rate of change you will probably want to use the derivative object.
If you want even more functionality you can use the sample object and perform rate of change calculations on the different values sampled. This requires a few more expressions and pulse objects but it works nicely.
Be more specific and I will try to help more.
Tommy Scharmann
