How can I delete alarms and event data from a Citadel5 database? There is a article (ID: 2NNAN9M9) that says how to do it using MAX but when you archive just the alarms and event there is not an option to delete the old data. I do not need the old data i would just like to delete it from the Citadel5 database.
It would be really nice if you could put together a working Lookout 6.5+ citadel control example (with all the proper syntax) to perform these deletions.
