10-26-2015 10:33 AM
I'm new to this forum and the National Instruments products overall. I'm really a network administrator, but I've been approached by our maintenance department to help troublehsoot the subject mentioned issue. This issue started last Thursday. I'm also pretty sure that there was nothing done to the PC to cause this to happen. I've listed my troubleshooting steps below.
Troubleshooting:
1. I didn't know if this issue was related to his NIC, so I made sure that everything was updated and working correctly. He only had a 10mb connection to the PLC, so I made sure that it is now at 100mb.
2. I attempted a repair, but it failed as it was looking for the media.
3. I found the media and attempted another repair that on the surface appeared to have worked, but when the program was launched the same error occurred.
4. I completely uninstalled (with the help of the Microsoft Fix It utility) all NI products except for NI Measurement & Automation Explorer.
5. I reinstalled the program, but noticed a lot of files were missing. Luckily I had backed up the NI folder before the uninstall was completed.
6. I placed all missing files back into their respective areas.
7. I examined the lookout.ini file to ensure that it was correct.
8. I relaunched the program and began to receive errors pointing at the .lks file. I ran the CBL utility and found the errors. I fixed what I thought was incorrect and re ran the CBL utility. It came back clean.
9. I relaunched the program and it appears that I'm back at square one.
Machine Specs:
Lenovo ThinkCentre
Pentium Dual-Core CPU
E5500 @ 2.80GHz
3 GB RAM
Microsoft Windows XP w/ SP3
FYI: I've also contacted Lookout support in Shanghai China. The only help the have provided is regarding the CBL utility.
Chris
